fred_dot_u
- Joined
- Jul 22, 2007
- Messages
- 11
I've searched the forum for any reference, but came up empty. That's not surprising, since this particular band isn't likely to be of much interest to many people.
I've recently tested for and passed my amateur technician class license exam. The primary purpose of this is to be a legal operator of a locator beacon for a radio control aircraft (RC PLANE, Communications Specialists Inc., RC Plane, Model Airplane Tracking, Model Rocketry Tracking, ELT) which operates between 222.xxx and 223.xxx MHz with some missing channels here and there. The manual for the beacon lists the precise frequencies:
http://www.com-spec.com/rcplane/manual/at_2b_transmitter_manual.pdf
The Pro-96 in combination with Win96 software allowed me to enter all the possible frequencies, which I've entered as conventional, in banks 3 and 4, with nothing else in either bank. When I turn on the scanner, I drop banks 0-2 as I am currently only interested in determining if there are other users on the locator frequencies.
I have to crank up the squelch, as expected, and it's set right on the edge of breaking, if there's even the slightest transmission. The speed of the scan is impressive, in that it does all of them in about one second tops.
The question lies in the lack of any local transmission, at least from the point of view of picking up any sounds on the scanner. I've set the frequencies correctly, and the type column is all set to FM and Conv. Are there any other parameters within Win96 that have to be changed from the default, in order to be assured that all these frequencies are quiet?
I'm not sure what other information I should be providing, but will be happy to append to this thread once anything missing is determined.
Is it possible that an entire band of channels are dead silent?
Is it more likely that I have the entire band set incorrectly?
I've read some of the stickies for this particular segment of the forum and none of them appear to apply here.
I've found this reference:
Modulation
Like the 6 metre and 2 metre bands, operation is typically CW and SSB in the lower band and FM in the upper band.
What field would I set in Win96 to determine if CW and SSB transmissions are being performed within these channels?
Additional research indicates that the 1.25 meter band is not popular or commonly used, and equipment with which to transmit in these bands are not easily found, due to geographic restriction.
thanks for your consideration
Modulation
