Pro-96 or Bearcat 296D
itsme
Brampton
Can anyone tell me the if the Pro-96 or Bearcat 296D is better for the new O.P.P fleetnet system.(in the GTA)
EJB
20 + year membership
Downtown Hamilton
Both will work fine. Its up to personel preference to choose.
Both can be ordered online quite easily,
The 296 can be purchased in Toronto or Durham at stores
I heard the 96 has better audio and I hear their battery configuration is better than the 296.
LarrySC
Greenville, SC
I have the 96. Have programmed 296 for local TV-station in addition to their 796's. The 296 is a little dorky. 96 is easy to operate. Also can be set up in trunking as test mode to find new ID's. PGM one bank with controller for MOT system. PGM all talk groups. Lockout all talk groups except for one or two that are not too busy. Run in OPEN mode [+] Anything new that comes on the air can be found in a second. Good Luck
mciupa
Canadian DB Admin
Moderator
I'm here a lot
The Pro -96 may be better for this reason :
Enter Control Channels only on VHF trunked systems
This detail will be a timesaver as the radio will figure out the remaining
freq's for each site. The BC296D requires you to program all freq's per site.
Another point is the "96" uses AA cells, (everybody has those handy), the
296 uses a battery pack.
Hmm....which would you choose ?
eyes00only
Denver Colorado
Don't know if this affects Canada, but if rebanding is in the future, both radios will become paper weights.
Jerry
grosporina
North York, Ontario
I'm pretty sure the BC296D can work from control frequencies only as well, at least if you beleive their manual, I haven't tried it myself.
I've heard that the main advantage of the Pro-96 is the capacity to store and recall more trunk systems, since with the 296 you're restricted to one per bank and there's 10 banks so you run out real fast but on the Pro 96 there folders in which you can store more than one set of banks?
motomeso
Ontario
Jerry
Most newer Uniden and RS models will not become paper weights with the rebranding, they will just require a firmware upgrade which will be made available when they know exactly what the final plan will be. Please read these threads before you post useless information to this thread.
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&t=21596
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&t=22155
