Pro 96 programing with arc 96
Tailspin
Prescott
I had my scanner programmed a few yrs back with win96 ...things change and I dl the arc 96 to program newer freq. into the scanner. Scanner worked great on trunked systems with the standard and 800Mhz ant.. prior to using the arc96 software
Here is what is going on now...after programing the scanner with the arc 96 software my reception is very poor with the standard antennas. When I attach my external ant. I am open to the world everything comes in fine.
I am not sure why all of a sudden this is happening...and it is a pain in the (*) when wanting to carry the scanner around in my pocket.
Any suggestions?
conventional and trunked freq. are in seperate banks as well.....
Thanks in advance
with the info given, 1st check the programing out YOU may have or have checked THe CC only option, also post link to the system you are trying to program. Software should make NO difference tho?? hmmmm
Tailspin
Prescott
sorry for posting this in here been a while since I was on this site and I see there is a software forum.
fyi the cc is not actual listed but I assume it is systems bandplan .. which I set to normal
at any rate I Downloaded Win96 and all if fine now
