Pro 96 Question
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
I've corrected the image - now as to the rebanding tables on this article, are those 2 wrong - they conflict with what you have in your table
73 Mike
Mike,
Tables O2 through 05 are standard default tables (not rebanded) and do not apply to this UHF Mot bank so are ignored. Should a user have need for an 800 MHz Motorola rebanded systems bank, they would merely open this dialog in that bank and click the 800 MHz Rebanded bullet under Standard Plans. You recently worked with Don and Mike V on the latter method so I bowed to you for these Wiki replacements. :p
BTW, in private Email with Gommert indicates he will be modifying his reband tables and release in next upgrade due out shortly. We'll get them up in the section he added recently.
command_z
Frank, thank you very much for your help. It seems to be working now. Hopefully I'm setup correctly.
Can anyone tell me whats the difference between "MPD 3D Patch, under the DCFD/EMS Bank 1" and the "MPD 3RD DISTRICT under bank 0?"
Also, what's the best bet for listening to MPD undercover operations? Last night I caught an undercover crack selling operation (I believe) on one of the TAC channels.
Thanks all!!!
