Pro-96 Trunk Speed
Mooreryanp
Hi,
I have a Pro-96, I monitor a few different systems. However one system seems to scan incredibly fast. (Ie. If I am scanning 5 systems, this one seems to have a slower delay while the cursur is on it).
http://www.radioreference.com/apps/db/?sid=101
http://www.radioreference.com/apps/db/?sid=90
Just to give a reference, the second one is the one that seems to "scan" faster. I do get traffic from both, and both are receiving at least a 95 percent rate.
(both systems seem to be identical)
(I have programmed with WIN96, and both are closed systems and have about the same talkgroups). I have also tested these by manually entering them as an open system with no programmed talkgroups.
Thanks for any insight on this... :)
It's simple?.. different systems sscan differently.. or at different rates. Has nothing to do with the scanner in most if all instances & can't be changed
