morrowcounty
- Joined
- Jan 5, 2007
- Messages
- 2
I hope someone out there can help me.
I had the scanner on all day on Sunday while I was around the house and it was working great. I turned it
off for about 2 hours while I watched TV and then turned it back on. When I did turn it back on, I was not picking up any channel.
I had a Pro-2055 in the other room and both scanner are set up with the same exact channel plan. When the Pro-2055 stopping on one of the talk groups of the local trunked network, the Pro-97 was still scanning.
Me thinking this was weird, put the Pro-97 into manuel mode and found the control channel on the trunked system. The scanner was getting a signal between 97-99%. I would usually get the motorola control channel noise, but no noise. I checked the volume and it was all the way up.
I next checked the local weather radio station by hitting the weather button, and all it was doing was scanning the 6 or 7 freq it has in there for the weather station. It was working fine on the Pro-2055. Both of the towers for the trunked system and weather station are about 1 mile from my house.
I still get the beeps when I hit a button on the radio, but no noise from any of the channels on the scanner.
Any one have a clue what is going on??? I have had this scanner for about 5 months with no problems but it was used for a short time before I received it.
Thank for all the help.
PS: I hope you can understand this. If you don't please ask and I will try to explain it more. Thank again.
