ProScan: pro scan software
KO4IPV
After registering , following the directions given after paying the fee of 50 dallars , it says to go to Menu ! and add the registration number issued. The problem i am having is , were is the Menu tab ????
KO4IPV
Yes! You can Download from Scanner to see the contents of the scanner in ProScan. You can make changes to the file using ProScan and then Upload to Scanner to load the updated file back into the scanner.
Thankyou a great deal ! Big help
KO4IPV
I have a question concerning the Download from scanner function! After my download is complete into my software, I am seeing 2 of everything I had uploaded to scanner previously , what is the problem is there something I am not checking in the ( Upload to Scanner) box before sending back to scanner?
tvengr
Well Known Member
Baltimore County, MD
If you highlight Delete All Systems Before Sending, it will erase everything the scanner before uploading the file. If you highlight Replace Systems With The Same Name, it will delete a system already in the scanner and replace it with the updated system with the same name..
KO4IPV
Just wondering about my proscan software home page in the upper right hand corner there is a small box with this in it ,Frequency tune Jump Number tag tune What is this used for ????
fxdscon
¯\_(ツ)_/¯
I approved this post to show what sort of crap we get on a daily basis.
Given the membership numbers and the huge exposure to the public that RR has, you guys do a tremendous job keeping things under control. I can only imagine what kinds of things arrive at your door every day. Keep up the great work, it's much appreciated.
On a side note... that post looked like it was replying to KO4IPV's post from 6/5/2022... Didn't threads used to auto-lock after 6 months of inactivity?
KevinC
32D2T/957.282
I'm everywhere Focker!
Yes, but auto-lock ended with Xenforo.
