pro2050 ex-spkr
tonyclark
Graceville, Florida
Has anyone put an ex-spkr jack on their pro2050. I think I'm going to tonight. The internal one gives me a headache.
KC5EIB
Flower Mound, TX
Why not use the headphone jack that is already on the front of the scanner as noted on page 10 and 11 in the manual that came with the radio?
From the manual:
CONNECTING AN EXTENSION SPEAKER
In a noisy area, an amplified extension speaker (such as Cat. No. 21-541), positioned in the right place, might provide more comfortable listening. Plug the speaker cable’s 1/8-inch plug into your scanner’s headphone jack.
pro92b
Mutated Member
The headphone jack does not connect directly to the audio ground, same as many handhelds. This limits the audio output to prevent hearing damage. That's why the manual specifies the use of an amplified speaker for connection to the headphone jack. To use an unamplified external speaker the ground terminal of the headphone jack would have to be connected to the radio ground.
tonyclark
Graceville, Florida
From the manual:
Yes I know BUT I don't have an amplified speaker or I would. All I have to do is drill a hole snip snip solder done. What I ask was has anyone done it.
Why dont you take pictures and document what you did so it can helps others and put it in the WIKI
tonyclark
Graceville, Florida
I would have but no camera, if I can borrow my sister's I can take the cover off and show what I did. It only took 10 minutes to do.
