pro96 trunking
blackgn6
illinois
I got a pro96 and where i live just switched to apco25, I have no idea how to program in TALKGROUPS??? Any help?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
and that is where, precisely? Go up to the blue toolbar under the site title and float your mouse over Database. Follow the various pulldowns. If your system is new, it might not be in there yet, but it's worth checking.
If you want to do this manually, here's a cheat sheet that will help...
Programming Shortcut Pro-96 - The RadioReference Wiki
This can be done via software, too - best regards..Mike
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
ok thanks i'll try this
What system are you programming? Reason for asking is if it's a multitable VHF/UHF P25 system, you will need software. Win96 is my preference but ARC96 is also available.
You may also need software if it's an 800 rebanded system.
Edit: If system is StarCom21 we need to know which towers (sites) you will be using.
blackgn6
illinois
starcom
yes starcom21 the sites i'll be using is this 1 IF that's what you mean. It's in Bloomington/normal illinois. Starcom started yesterday here
fmon
Eclipse, Virginia
Bloomongton is yet to be in data base, but not long ago, I think Don Starr indicated the Pro-96/2096 does not require rebanding tables for P25 trunling systems. Thus programm all 800MHz control freqs and Alt control freqs.
This scanner can't trunktrack system if the new tower uses 700MHz freqs.
blackgn6
illinois
my scanner needs reformatted and i dont know how. Anyone here know anyone or anyplace the will reformat frequencies?
