Pro96com newbie
ve5wil
Moose Jaw
Hi all. Well since unitrunker now refuses to work for me., i decided to try pro96com for logging channel grants (from Uniden Scanner). ive noticed a couple things:
1 Some times it is not picking up grants that Dsdfastlane is showing, or that i can hear from a second scanner
2 that the channel grant window clears randomly. is this something with the program or a setting i may of missed/ Id like a continuous screenso i can see what ive missed when not at the computer
thanks
Spitfire8520
Might be slightly less clueless! =)
Colorado
Assuming that you are manually holding on one control channel, then both points are signs of the scanner having poor decode of the control channel, which can be caused by a weak signal or simulcast. For point 2, if the scanner incorrectly decodes the system or site ID, it will wipe the screen and start a new log thinking that it is receiving information for a different site, and then repeat the process when it gets updated information with the correct system or site ID.
