PRO96Com/TRX-1
Kel
Southwest Florida
Can't seem to get it to work with my unit,saw on one of the threads I believe there is a setting on the unit to be set any help would be appreciated,works fine on my 800?
mikey60
Oakland County Michigan
From the scanner's main menu, select the Program Menu and then Global Settings.
Then check the PC/IF CCDump option and uncheck the to file option below it.
Save the configuration and then try again.
Mike
troymail
Silent Key
Perhaps obvious but you need a good quality CC signal (I assume you have that) and you should HOLD on a lightly/unused talkgroup (or create a dummy TGID like 9999 to HOLD on).
Having said that - what is Pro96Com doing/saying (or not) when you try to run it against the TRX-1 signal/feed?
You said it works fine on your PSR800 -- same system/control channel?
