Problem with Control Channel Only Programming
bigmattyl
Orange County, CA
(Xpost from my local forum)
Here's my setups...
I have:
BC245XLT
BC780XLT
BC796D
With the CountyWide cell
I have the BC245 programmed by having all freqs in the back, BC780 CCO Plan 1 and BC796 CCO Plan 1 and everything works great.. when i run them all at the same time they all pick up the same stuff perfect...
My problem comes with South and North cells
The 245 works fine with all the Freqs in the bank, and BOTH the 796 and 780 programmed CCO Plan 3 dont work... the 245 will catch the transmission while the other two stay on ID search... (Also the Trunk IDs are the same in all three)
Now if I change the programming in the 796 or 780 to the old method of putting all the freqs in.. they work just fine... I dont think its the scanners because the odds of them both being broken in the same way are small...
For Reference here is the freq for south
866.12500 866.17500 866.37500 866.62500 866.87500 867.12500 867.37500 867.62500 867.82500 867.87500 868.12500 868.37500 868.62500c 868.67500 868.92500
and here is the descriptions for the plans....
  • PLAN 1: if the last three digits of ALL the frequencies in use end in one of the following three digits: 125, 375, 625, or 875 (example: 856.1125, 860.7375, 859.6625, 855.8875).
  • PLAN 2: If ALL the frequencies are less than 869.0000 and end in one of the following three digits (125, 375, 625, or 875) and if ANY other frequencies end in (000, 250, 500, or 750)
  • PLAN 3: If the last three digits of ALL the frequencies in use end in one of the following three digits (000, 250, 500, or 750)
  • PLAN 4: If ALL the frequencies are less than 866.0000 and end in one of the following three digits (000, 250, 500, or 750) and if ANY other frequencies end in (125, 375, 625, or 875)
Northi is very similar... What am i missing???
Thanks so much for any help! =)
Matt
