BCD436HP/BCD536HP: Problem with Firmware Update
rangers38
Morris County
Trying to update the firmware on my BCD536HP. I did a clear data on the unit, and installed a new Favorites list on the scanner with Sentinel. When I tried to updatethe firmware to see if the unit had the most recent update, I get the following error message. Any Help?
nessnet
What month is it?
That is a communications error with the server.
Nothing to do with the radio itself.
Looks like your FTP is being blocked by a firewall or your ISP(?)
Or.... not 100% sure on this, (someone can correct if wrong), if the Uniden server is down, is this the same error message?
tvengr
Well Known Member
Baltimore County, MD
I will have to try it again, My internet service may have been down or interrupted.
Who is your internet service provider? Some ISP's have high latency and others block the FTP port that Uniden uses. Is this the first time you tried to update the scanner?
