problem with ht 1000
rescue15
i have a ht 1000. i have my other radio set to the same channel and can recieve transmission on it but not the ht1000 is there a problem with my radio and can some one help.
gewecke
Banned
Illinois
Check to make sure pl tones are either the same on both, or off. also check to see they are simplex/ repeater?
73,
n9zas
rescue15
ht1000
thanks for the help on the radio.i wnat to know more about this ht 1000 .can you only select on two channels two scan at a time three at a time or four at a time.if not what portable should i get to fit my needs and from who.
KyFireFreak
Northern Kentucky
If your radio is only 2 channels, then that's what you have. If you have 16 channels, then you can scan all 16 channels. All about how you program it up.
rescue15
thanks for help before.Ok i just had my friend program the radio so i know the programing is right.Can some one help me .My radio in the car receives a call but the ht does not.What could be the problem.Is it on the receive part of the radio.Does any one know of a good repair company that would work on it.If not does any one know of a good person i could buy a good radio from.Thanks
rescue15
ht 1000
sorry for posting twice.Is there any one that could help me.Could there be a problem on the recieve part on the radio.We have a motorola dealer close.What radio would anyone get next.
dixie729
Daviess Co., KY
I've found from experience that if you use the HT 1000's you can't hear transmissions from other model radios. I had that problem at work. Other deputies could not hear me.
Sent from my Desire HD using Tapatalk
nrembis
Mount Orab, OH
We dont have that problem and our county uses a mix of radios from Icom, Vertex, Kenwood and Motorola. I program my FD's HT1000's and they work just fine receiving from other radios, If anything, it would be the motorola radios jacking up the others since they use a non standard reverse burst compared to the rest of the industry.
The problem with the OP's radio must be in programming or faulty radio
Ive had a sorta similar problem with one of my ht1000's... I could hear everything RX just fine but there was no TX audio. Long story short the radio belonged to the City utilites before I bought it at auction and it had seen some use, pretty banged up. Im guessing loose connection somewhere. So depending on how old the radio is and if its had a rough prior owner that could be the problem. On my jt1000 I had another problem sorta similar, but this one had to due with a programming issue... all data was correct so I reloaded the data into it and it worked fine
