ST-Bob
OK, on the conventional frequencies from scanlist 1 did you set the CTCSS tones or DPL codes for those frequencies which have them?
On scanlist 2 you're listening to a VHF P25 digital system. You need a really good signal to get digital clearly - much stronger than you did with analog from the same location. Multipath reception (signals reflecting off buildings, mountains etc.) will kill digital reception which is usually either "perfect", "broken up" or "gone entirely". It sounds like you're getting weak or reflection-damaged digital P25 reception. A better antenna or removing nearby "problem frequencies" like the paging systems you're getting so strong will vastly improve that problem.
I don't use PSREdit (I use Arc software) so I cannot tell if you imported the stuff correctly from the RR database. Do you have the PL tones in your computer before writing to the scanner?
You mentioned the paging stuff. If you ever hear it coming in along with the analog frequencies, sort of "on top of" the police/fire stuff then you have intermodulation distortion and have to get rid of it before you have much chance of improving either analog or digital reception. Get a filter.
