Problems with hidden channel scan and missed transmissions
Hello all! I have a question about an XTS5000 and monitoring digital trunked system via the hidden channel method. I have two different systems programmed in here. (I am well versed in the CPS and programming) but for some reason one of the systems works perfectly and receives 100% of the time, whereas the other system talkgroups are coming in maybe half the time. What could I have missed when programming the other system in there that is causing missed transmissions? Perhaps preferred site settings? I'm just a little stuck on this and tired of plugging and playing with it. Thanks in advance! -Will
Odd i have similar issue but one site works good if i keep smartzone disable otherwise want receive it
Sent from my LG-H343 using Tapatalk
Yup, it was a roaming issue. Didn't have site preference parameters setup properly. Duhhhh. Need to take a break from this computer.
