Programing Baofeng UV-82 through Radio Reference
Rescue2
Brooklyn, NY
I am a premium user of Radio Reference and I am trying to programing my Baofeng UV-82s using Chirp. Using Chirp to program my radios is a breeze but I can not figure out hoe to set up Chirp with frequencies from Radio reference. I can't query or do anything else for that matter. Can someone please rescue me? Thanks.
It's actually pretty simple, first make sure you have the newest version of Chirp installed.
1. Hook up the UV-82 with programming cable, go to the "RADIO" tab at the top and click on download from radio.
2. After it downloads then go back to "RADIO" tab and select "IMPORT FROM DATA SOURCE"
3. Enter in the RR user name and password, then enter the zip code where the frequencies are located you want to load into radio. Click OK.
4. You now will see the list of available frequencies, freqs greyed out aren't compatible with your UV-82, check or uncheck freqs you want, use the +/- buttons to adjust frequency channels you want to load on your UV-82. Click OK and they'll load into the UV-82.
5. Go back to "RADIO" tab and choose "UPLOAD TO RADIO".
That's it! Good luck!
