BCD436HP/BCD536HP: Programing BCD536HP questions
bigbass91360
Northern Ohio
we used the sentinel software and put my county P25 then sub folders under that same favorites to add some conventional frequencies.
When I scan that system it don't seem to pick up anything but the P25
hiegtx
Dallas, TX
If you are trying to put conventional frequencies into an existing trunked system, P25 or otherwise, that will not work.
They need to be in a separate, conventional, system. Both can be on the same Favorites list, but not in the same system. If that's not what you are refering to, export your Favorites list into an *.hpe file, then post it. You'll need to either zip the file before posting, or change the file name slightly. To post on the forums, the file extension must be one of the recognized ones. *.hpe is not. So, say you export to 'myfile.hpe' (without the quotes, of course). To attach it, rename it to either myfile.hpe.txt or just myfile.txt. If zipped, using WinZip or 7Zip, the file would be myfile.zip.
