R6 Programing with CS-R6
rocky28965
Otago, NZ
Is there anyone on here familiar with the CS-R6 software program.
I have created a program and written it to the radio.
It works just fine but, in the program, there are gaps between the program groups.
For example: Bank F finishes at CH 187 but Bank G starts at CH 201.
There are several gaps like that.
I'm obviously doing something wrong.
pb_lonny
VK7AAL
Tasmania
Hi. Yes I have. Can you take some screen images of your banks and I am happy to take a look.
rocky28965
Otago, NZ
I tried to attach the program file but wasn't allowed.
So, here are the two banks mentioned in my 1st post.
pb_lonny
VK7AAL
Tasmania
You can add whatever channels you want to each bank, how do you want it to look?
rocky28965
Otago, NZ
I expected the banks of frequencies to progress numerically through the available channels.
For example, Bank F finish at CH 187 and Bank G starting at CH 188
pb_lonny
VK7AAL
Tasmania
The R6 has 22 banks but 1300 channels, so in your images, if you go to the "All" folder, you will see all the frequencies you have saved, you can then assign them to one of the 22 banks. But as each bank can take 100 channels, you can't have 100 channels in each of the 22 banks, as this is over the 1300 channels total.
The channels are referring to the saved channels under "All". You can assign each of these to a bank but the numbers are just a reference to this.You could have Bank A with channels, 1,5,71,501,14,77 or whatever you want.
rocky28965
Otago, NZ
Ok that makes sense.
I'll do some copying and pasting and fill in the gaps.
Thanks for your help.
