ProGrammer Assistance
Prospect62
20 year member
Oneida County, NY
Hello. This question does not pertain to trunking really, but maybe someone can help. I just bought a KMC high band VHF mobile and then realized that my EDACS 4 ProGrammer doesn't do the KMC. I've only owned MDX's so far and what I have has worked fine. I have no idea what "revision" of ProGrammer I have, but does anyone know what "revision" of ProGrammer has the capability of doing KMC radios? If anyone can steer me in the right direction I'd appreciate it.
rescue161
KE4FHH
Hubert, NC
The KMC looks like it can be programmed with version 18 of the Programmer software.
To find out which version you have, open the software and then select help abd then "About Programmer".
rescue161
KE4FHH
Hubert, NC
Prospect62 said:
Mine says R03A03, does that mean I have version 3? I don't see KMC anywhere in my list of supported radio... :(
Yep, you have version 3.
tbski100
Central NY
What is the latest version of programmer?
I have v17 but am getting an error when tryng to read. Says it is too old of a version or something to that effect. What are my options?
rescue161
KE4FHH
Hubert, NC
You should be able to create a personality and write to the radio without reading it. If you want to see what is in the radio at present, you'll have to upgrade your software. It is up to version 20 I think.
tbski100
Central NY
yah i could just write in what i want, but i wanted to read and save what i had so that if by chance it went bad i had the original personality to revert too.
thanks for the info Scott.
rescue161
KE4FHH
Hubert, NC
The only thing you have to worry about is losing the tracking data and the feature encryption. You can read and save that info using the Radio Maint program. It is highly advisable to do that too. Once you have those items, you can recover the radio. If you don't save that data and something does go wrong, it can get very expensive to put it back to normal.
The personality file will do nothing to recover the radio if something goes wrong. If you just want to know what is in the radio, then you must upgrade.
tbski100
Central NY
thanks for the further tips. I did save the tracking and feature data to my pc.
but........ upgrade is easier said than done.
thank you for the tips though.
w0fg
Decorah, IA
Anyone know where I can find an older copy of ProGrammer? It doesn't need to be able to handle anything newer than M-RK II's. I haven't had much luck with Google searches.
dfdmedic38
GE Programmer Software
I have version 17a. Does anyone have a new version?
WayneH
Forums Veteran
Your master site
dfdmedic38 said:
Is there anyway I can get a copy of the newer software?
Open your wallet and pay for it. It's not Kenwood cheap but it's more easily available from MA/Com than Motorola CPS.
And you better not be publicly asking for copyrighted software on here.
dfdmedic38
My question could have been phrased differently.......The dealer in my area won't sell any copies of the software. Does anyone have contact info so that I can purchase it?
WCRadioGuy
Salisbury, MD
Call 1-800-528-7711. I think the you choose option 3 for software services. I'm pretty sure the software is around $1200. With the new software licensing, copies can no longer be made and passed around.
blah546
Does anyone have a list of changes/benefits of the newer versions over the years?
