Programming a Kenwood TK-620
knockoffham
Michigan, USA
Hello. What programming cable does this radio use? I have a copy of KPG-21D, but am getting a communication error using a serial cable and DOS box. I use DOS box with many other Kenwood and Motorola DOS-based programs with no issues. I do have a real DOS machine I can try as well, but actually have less success with that than DOS box. Does it not use the standard microphone jack programming cable? If not, does anyone have photos, part numbers, or pin outs of the cable I should be using and where it plugs in? Thanks
knockoffham
Michigan, USA
The oldest PC I have is a Pentium II. I hear this program is finicky with CPU speed. Could that be it? Although usually DOSbox works on RSS/CPS/FPU programs that require a low CPU speed.
n7maq-1
Oregon
You need a KPT-50 and that plugs into a connector on the inside of the radio. Or you can use a KPT-20 EEPROM programmer.
Jim
tlemke940
Lyons, OR
just a question as the timing of this posting is just interesting was this the tk-620 that was sold on eBay recently?
tlemke940
Lyons, OR
oh no real reason i thought it was interesting that this poped up after that radio sold at the beginning of June.
knockoffham
Michigan, USA
Thay pop up on ebay here and there. There is a rough kpt-20 on there at time of this posting.
Yes. However I paid about $30 for the radio, so I am not planning on spending $200+ on the programmer. I reached out to a former radio system admin and Kenwood LMR employee friend and he said he hasn’t even seen one of these radios in over 10 years let alone programmed one, just remembered you had to remove the case to program it. Likely I will be cutting my losses.
tlemke940
Lyons, OR
it is too bad no one in the area has a programmer that could program it for you sad to see a good radio like that get put on a shelf and forgotten. and ya the programmer on there i was not recommending due to what looked to be water damage just tat that do pop up and i have seen them as low as 50. if i was in your area i would help program as i do have a programmer
n2mci
Kingston, NY
Is this the mobile TK620 and not the TKB-620? I believe the KPT50 is only for the TKB and TKR series of radios.
With that said, I removed 93C46. Eeprom and was able to change the freq data. It was on a UHF 820, but it's the same
on the 620.
From what I've seen in the file saved by KPG 21D prg that works with KPT50 and the actual Eeprom data, the data is the
same, it's just the 2 bytes are reversed. ie '1234' vs '3412'
I don't have a KTP50, but maybe you could read/write and then reverse the bytes, so the KPG21d program could then read
the data? I did write a simple program to reverse the bytes.
Some to consider. Pete
knockoffham
Michigan, USA
on the 620.
Thank you. That is some very useful info. It is the mobile, not the base. Perhaps I will get an EEPROM programmer.
