poppafred
Hi folks,
I just won a Pro-197 on eBay and it is enroute here. I am hoping I will know what I am doing by the time it arrives. I already have the Radio Shack programming cable and downloaded the newest drivers for it. I bought Win500 right after winning the auction & signed up for Premium membership here.
That should be all I need, right?
So.....
I am used to programming my Pro-97 with Win97 but have never tried the Premium membership on Radioreference.com before.
I fired up Win500 and set up the web import. I went to the RR.com link, signed in and found the major state-wide P25 trunking system for Arkansas, called "AWIN". I followed the UtahRadio instructions and downloaded the trunking system and stored it into Win500. Where should it be stored? Does it matter? Are there folders I should avoid uploading to?
Is that all I do before uploading it to the scanner? Did I read correctly that the scanner has to be in manual mode to upload to it properly? Do I have to worry about associating TGRP and TSYS since the software downloaded and installed it into the memory?
I cannot find ANY instructions on Win500 except for the UtahRadio page. The scanner manual (downloaded the PDF) does not have a thing in it about importing with Win500. Not very easy to read off the computer, I'm a hard copy kind of guy. Win500 does not have a help file yet.
The "V Folder" for Arkansas (#11) does not contain the AWIN system so I will probably not keep any V folders in the scanner. I found a zip file containing them on the Win500 page so I downloaded them and saved them to my hard drive for later.
UtahRadio says "It is considered scanning in "Open Mode" if there is a Wildcard in working memory while scanning." What is a "wildcard" and how do you add one?
Sorry this post is so long, thought I should ask as much as possible all at once and go from there.
Gee, maybe I should write a Win500 help file with all this once I get it figured out!
So.....
