Programming Cable For CDM1250
sam55671
NJ
Hello,
I would like to know if I can use Solid wire to make a programming cable for a CDM1250. I want to use a CAT5e Cable.
Thank You
Sure, it would work.
Problem is constant flexing might be an issue. Stranded conductors tend to hold up to flexing a lot better.
What you don't want to do is have the conductors damaged while you are in the middle of programming a radio. Bad things can happen, corrupted codeplug, etc.
sam55671
NJ
I am making it for a friend, I will tell him about the flexing, thank you.
I needed a cable to go between the RIB and a CDM radio, and didn't have time to order one. I built one out of a DB-25 connector and an old Category 5 Ethernet cable. Been using it for years.
You can also program these radios using the rear 20 pin connector.
sam55671
NJ
That is what I am doing, using a DB25 Connector.
sam55671
NJ
Do you have any knowledge in the XTS Series Portables?
Minimal. I used them on an 800MHz SmartNet system up unit 5 years ago. I've got a few in use on a VHF analog system. All XTS-2500. Open a new thread, those are popular radios and there are a lot of people with way more experience with them than me.
sam55671
NJ
Ok, thanks for the info about the cable.
