Programming cable for Motorola XTL5000
com501
It means someone did not have a clue what they were doing and programmed radios that ended up affiliating and causing the talkgroups to revert back to Phase 1 FDMA. I LOVED inhibiting these radios as a system manager.
As for your second question, everyone will say they make the best, but there are TONS that create just horrible programs that have absolutely no business being anywhere near a programming cable and a copy of CPS.
Phase 2 with encryption and authentication. Everything else gets nuked.
prcguy
I have the factory accy connector with USB programming cable loaned out, when I get it back I can post the part # and a picture. I've seen them on eBay from time to time and a guy at the last Dayton Hamstervention had some for $5 each and that's where I got mine. There is a serial version on eBay right now but its pricy.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Worth noting, if you have older firmware on your XTL, the rear USB accessory programming cable may not work. The serial one will always work with the XTL...but won't work with the APX. Also, if you have a high power brick configured for a W series head...you have to have the HKN6155 cable unless you want to swap out for a Odyssey TIB every time you program (which at that point you might as well rock an O series head so you can easily upgrade to APX later).
com501
Trust Motorola to require 6 different programming cables for a single radio version, depending on FW or feature sets.
