Programming cable for Motorola XTL5000
Johnpayette
Houston
I am looking for a programming cable for the XTL5000 that plugs into the microphone port. Its a square plug not for 05 heads. I already have a cable for the xtl2500 that you plug in and rotate
nhfdcadet
CETsr
New Hartford, Ct
is it absolutely necessary that it goes through the mic port? I had found one on ebay a while back that went to the back accessory port, its been good for me.
Echo4Thirty
Colorado Springs, CO
If its the W Head like used on the old Spectras you are better off programming it through the rear. Moto did make a mic jack serial cable for the radio, but they are rare and insane expensive when they do come up. No one ever made an aftermarket for a couple of reasons. There is a circuit that would have to be duplicated and popularity. We had a couple of the cables on the ancient fleet of W4's we maintained for programming in-car.
I never have seen a USB W mic jack cable.
EDIT: The serial mic jack cable is HKN6155
Johnpayette
Houston
Thank you for the part number. The front plug in is a little high for right now. I am just learning to program these radios for Tow Trucks to monitor Police and EMS
KevinC
32D2T/957.282
I'm everywhere Focker!
Houston area has a lot of TDMA so you may want to look into something that will do TDMA.
Echo4Thirty
It means someone did not have a clue what they were doing and programmed radios that ended up affiliating and causing the talkgroups to revert back to Phase 1 FDMA. I LOVED inhibiting these radios as a system manager.
As for your second question, everyone will say they make the best, but there are TONS that create just horrible programs that have absolutely no business being anywhere near a programming cable and a copy of CPS.
prcguy
