I'm about to pick up the scanner from facebook marketplace. Does the usb cable with the scanner also work for PC programming or is that a separate purchase? ๐๐ hope not.
I believe it's supposed to but don't hold me to it. If it doesn't have one it's a simple mini-usb cable..... Which are fairly common and can be picked up for cheap. If you don't mind me asking, what are you trying to listen to? (IE: State, County)
Just gonna be for monitoring area ATC and local services here are still analog. I don't have any airband radios with the 8.33 steps. Other counties here are digital but moneywise that's totally out of the question.
You can tell I've been out of it for awhile. ๐
Supplied cable worked. Scanner has latest firmware and not a scratch. 50 bucks, no complaints. Already have the Diamond RH-77CA. It works *great* on air band!
