BC296D: Programming cable
JoeBearcat
Inactive member
Uniden Representative
Last I heard, I think they were out of those cables, but by all means contact them to verify.
tvengr
Well Known Member
Baltimore County, MD
Joe, how about this cable? Amazon.com: USB Serial Programming Cable for Uniden Bearcat BC250D BC296D UBC3300XLT BC246T BR330T BCD396T BC346XT : Electronics The serial plug photo looks correct. The thing that concerns me is that the ad mentions scanners which I know do not use the same plug as the BC296D..
ftdi ft231 rs232 to mini usb 4p cable for Uniden Scanner cable,uniden bearcat BC250D BC296D UBC3300XLT BC246T BR330T BCD396T BC346XT BCD396XT BCT15 BCD996T
JoeBearcat
Inactive member
To be blunt, the 296 is before 'my time', but are you sure it is not the hirose connector? I don't have one to look. (the 250/296/3300 might be the only models I don't have)
tvengr
Well Known Member
To be blunt, I don't know what a Hirose connector is. The 296 connector is much closer to being square compared to the RS232 rectangular shaped connectors used by the other scanners. I have a 296 cable left over from programming a news department scanner many years ago.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That's right - the standard 296 cable is a straight serial cable, as that what was common in those days. Of course now, I think now you would need both the serial cable AND a USB cable to connect to most PCs now....
Could you possibly use the very old 245 cable? I seem to recall that the cables were pretty close....
Mike
tvengr
Well Known Member
The 396T, 996T, 396XT, and 996XT all use the same cable which is definitely different from the 296. My 296 cable does not fit any of them. Whoever created the ad for the other cable needs to do better research. I seem to remember that at one time Scanner Master carried the cable for the 296.
tvengr
Well Known Member
Joe, how about this cable? Amazon.com: USB Serial Programming Cable for Uniden Bearcat BC250D BC296D UBC3300XLT BC246T BR330T BCD396T BC346XT : Electronics The thing that concerns me is that the ad mentions scanners which I know do not use the same plug as the BC296D.
Found these reviews for the cable advertised:
Michael Martin
1.0 out of 5 stars Does NOT fit BC296D or UBC3300XLT
Reviewed in the United States on January 21, 2020
Verified Purchase
Headline says it all. The connector is too big, won't fit in the programming slot. Had to return.
Helpful
Report abuse
PaulieP
1.0 out of 5 stars does not work
Reviewed in the United States on October 1, 2020
Verified Purchase
cable does not fit the radio model number advertised
seedtick
S B
woodville,texas
I bought one ,not this one,and it said it would work but it doesn't.i called scanner master and talk to a human,and they told me they do not have one and said they couldn't order one.
JoeBearcat
Inactive member
Google USB Serial Port adapter. You should find many. Any quality one should work fine. Beware of older fake chipsets.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As for software, don't walk, run and get ProScan. It supports the 296...
The author is here, and the support thread can be found here...
Mike
JoeBearcat
Inactive member
It's not the serial port that's my problem,it's the bc296d end I can't find.
That is a completely different issue. I was responding to "I found the original remote control programming cable but my current laptop does not have a serial port. " which does not mention a 296.
Yes, a 296 cable is going to be very hard to find these days.
tvengr
Well Known Member
I have recently retired and working to get my old BCT 15 set up with local frequencies. I found the original remote control programming cable but my current laptop does not have a serial port. Scannermaster shows a replacement cable is out of stock. Would this cable work?
Use this USB to serial converter adapter cable along with your original BCT15 programming cable with the DB9 connector. It goes between the computer and your cable and works very well. Insignia™ 1.3' USB-to-RS-232 (DB9) PDA/Serial Adapter Cable Black NS-PU99501 - Best Buy
