Programming Help needed Unication G4?
Cactus2
Santa Fe, NM
I am in need of some direction on programming a G4. I have programed several systems and done OK but now I’m stuck when I try to either edit a file or program a new file, it allows me to go to Radio reference get the data create a named file but when I try to click down on I believe it’s E7 in order to see the matrix of zones and knobs there’s nothing present.. I can’t get it to copy over even though I asked for file from Radio reference and posted in zone one, Knob 1. What might I be doing it seems to me like it’s not excepting the new file and I’m evidently not including some possible protocol or perimeter and it’s worked in the past for some reason I can’t get it to now. If it matters I’m using that latest version of PPS version 4.0.32. Thank you in advance. So Frustrating??
First update your PPS, current version is 4.0.36
You can not edit a file using RR download, you either start over (deleting what you imported before) or manually edit it, either of these steps are done in the Customer Public Resource Manager Tab C-C1. Once that is updated the system will display it in Tab E-7 when you try to enter a system and TGs.
peteymcsweety
cincinnati. Ohio
Do you still need help..??
