Programming issue XPR3500e
Mtnrider
Greene County New Yawk
I have two XPR3500e's that will not see the cable. Computer says will not see (recognize) cable on just these two.
I have programmed a bunch of others .
All same model.
Any hints ? Tricks ?
K2NEC
5F6
Could be damage to the flex that's preventing proper communication with the computer
RadioGuy7268
PA
Yes, the quick check is to swap housings with another radio that is known to read properly. If the same guts in the 'good' housing have an issue with reading, then you know it's a problem in the internals.
If the radio now reads properly, it's safe to say you've got a problem with the flex. Wouldn't take but 10 minutes to check, XPR3500e housings can be swapped pretty quickly.
