Programming MD FIRST into BCD536HP Help
MDRadioGuy
Montana
I live in Western MD am very new to programming P25 systems. I am trying to program in the new MD FIRST system in my BCD536HP. I did a "discovery" search and picked up 772.9937 at an S-7 and it shows on the screen as DAT. Is this the control channel? How do I program it in to decode so the scanner is not hung up on this one freq.
Thanks.
jonwienke
More Info Coming Soon!
VA
FIRST is already in Sentinel. You don't need to program it, it's already there. Make sure the database is up to date in Sentinel, and written to the scanner from Sentinel.
tglendye
Blue Ridge Mountains, Shenandoah River- VA
Jon has given you the easiest way. I see you're newer here. Need some help? Have you used Sentinel before? Any questions, just ask. Myself or someone can chime in.
MDRadioGuy
Montana
Thanks guys for your quick responses. I have Sentinel and know how to use it , but I live in Allegany County and so far MD FIRST is not programmed in. That's why I listed the one freq I pickup easily and was asking for help to program it to decode it myself.
jonwienke
VA
It's in Sentinel. Look under other counties. You can copy the entire system from any county that shows it.
UPMan
In Memoriam
Arlington, TX
FIRST is listed in Allegany County in Sentinel. Very last under Statewide (First Responders Interactive Radio System Team (FIRST)).
ThePhotoGuy
Maryland
While you are correct, it does not have Allegany County or Garrett County Sites yet since those towers are not fully up yet.
Allegany Should be up by Summer. Garret late summer/early fall.
UPMan
In Memoriam
Arlington, TX
It does have several in Washington County. It is possible that one is close enough to cover all or part of Allegany, too. Or, the OP could be traveling into other counties and wants it programmed for such trips.
I see UP man has added NXDN to 436/536 as upgrade option on Uniden RR board.
Thanks!
wmbio
Cumberland, Md
Western Md
UPMAN is correct.
The FIRST towers in Allegany county md are up and down as of this morning....more tweeking will be needed.
As far as I can hear the Garrett county towers are not up and running.
I submitted the Allegany county FIRST yesterday to the RRDB
Enjoy
Wmbio
maus92
OCMD
July/August is the official cutover for Allegany County. They just let a contract with Motorola to install new equipment in their EOC to enable their dispatch operations interface with the FiRST system. Allegany County will be covered by two simulcast cells (which is a group of individual sites / towers,) and several standalone ASRs (single site / tower.) Not all are up on a continuous basis. The Sidling Hill ASR (the freq that you received i.e. 772.99375) and Washington County simulcast sites should be receivable from the eastern part of Allegany County, although Allegany County services may not be on the air. You might hear some state police and SHA operations.
