Programming motorola on a kenwood repeater
slobonmycob
Radio Freak
I've run into a doozy. I'm trying to program a conventional freq. in CPS. The Tx DPL code for the kenwood repeater is 634 but cps doesn't list that as the option. I'm hearing traffic on the radio just fine but i can't get the transmit to work. Any help much appreciated.
AM909
Radio/computer geek
SoCal
634 should be equivalent to 132.
nokones
Sun City West, AZ
What model Motorola do you have? My XPR radios will take the non-standard DPL codes using CPS2.
AM909
Radio/computer geek
SoCal
I tired it didn’t work.
I can hear traffic just fine but can’t transmit
OK – I confirmed it with a TK-3180, for which KPG-89D lets you program any DPL code.
Both of these TX/RX fine with a CCR programmed for D132N (and, just for completeness, do not work if it's programmed for D134N). Sure you didn't typo somewhere or maybe it's an "I" (inverted) code instead of a "N" (normal) one? The inverted equivalent is 546. All 8 of these codes are indistinguishable OTA (+ for N, - for I), though they are all "officially" known as 132N or 546I:
+132​
+605​
+634​
+714​
-317​
-546​
-614​
-751​
See DPL / DCS Information as a good reference for how and why and the other equivalences and edge cases.
Pittsboro IN
When I got to the LA Bearcom office years ago to pick up radios for the Rose Bowl game I found the rental guy had non standard PLs in the portables that the GR300 repeaters would not work with. The portables were set at 12.5 kHz which the repeaters could not do and 2 channels only 75 kHz apart had the same PL.
