programming mts2000
dss261263
UK
had these for years usually program from back serial of xp machine using one connector in serial computer and the motoropla clamp that goes onto the contacts at side of radio, using the cps 4 and I purchsed 6 a while back, the cable seems connected properly the port is showing when asked to read the radio, which is switch on it says cannot open port make sure switched on. is there a button sequence I must use to put mts2000 into programming mode or ?, I have two similar programming cables tried different xp machine with serials and they both said the same, cannot connect check the radio is switched on this is com 1, i tried via a usb serial cable to get another port same thing, is there buttons on the radio I must press to allow the radio to talk to the cable and computer. thank you in advance, David
There is no key sequence to put the radio into programming mode.
MTS2000 CPS went to version R02.03.00 -- there was no version 4 or 6. RSS, the older DOS software, went to version R06.08.00.
It sounds to me like you're using the wrong CPS. Or... if you're using a USB/Serial adapter, the drivers may not be installed properly. If you are, in fact using RSS with a USB/Serial adapter -- that is not going to work.
I dunno - your post is hard to understand.
dss261263
UK
Hi
I looked at the software the number is cpa r04 which I got from one of my old discs will see if I can look at the version number you listed and let you know if I get success with this, the programming cables are what I used years ago to do the job. thanks for a realy quick reply and I wiill let yo uknow how I get along.
Thanks and have a great day in the sunshine state.
David
mikewazowski
Staff member
Forums Manager
Oot and Aboot
If you are using RSS R06.08.00, you'll need to boot into DOS mode.
You cannot use RSS with a Windows XP DOS window.
dss261263
UK
HI Guys
Thanks for the replys, it says cps r06.04 that was a disc I found whilst looking, if uyou could please let me know what cps or rss number I am looking for to work on an xp machine sp3 if that makes a difference and I can go look at my back up discs tomorrow.
Thanks again for your quick assistance
David
KG4INW
Midlothian, VA
If it actually is CPS (Windows based) that R06.04, that sounds like Professional Series which won't work on an MTS2000.
dss261263
UK
Hi Guys, a quick update, you have pointed me in the right direction I came across the appropriate version, ver 2 or R 2 so am on the right track, simply need to find the version that communicates with my radios. Thanks again and have a great day there in the US.
David
