programming mts2000
captmud
massillon, oh
recently acquired an mts2000 vhf. read radio and tried to prgram ham frequencies in it. everytime i try to write to the radio it says verifing if radio can accept sodeplug, then just quits. no error messaging. i have used this laptop and cable for many other radios including mts2000;s with no problem. tried switching to an old win98 laptop with the serial cable. everything fine unitl i try to write radio. recieve error message "This Application not supported" any ideas?
RFI-EMI-GUY
Is this a new install of the RSS? I had a problem with some RSS for Systems Saber where inadvertently the RSS files were archived/read only when installed in the DOS computer. It created a communications problem when writing the radio.
RFI-EMI-GUY
new install on 2nd laptop. original laptop reads and writes my other mts2000 fine
check the attributes of the RSS system files to see if any are write protected or archived. These can be undone. Not sure the DOS command. I think attrib and some command line suffix
captmud
massillon, oh
solved the problem. I used the mt2000 dos software instead of mts2000 cps and it works fine. I noticed the codeplug was last updated in 1999
cmdrwill
So Cali
So, you have a MT2000 radio. Someone may have swapped housings or used the wrong label. What does the serial tag have for a model number?
And does that match what the RSS software reads back from the radio?
rescue161
KE4FHH
Hubert, NC
I had an MTS2000 that would not program with CPS. It had old firmware. I recently gave it away.
rescue161
KE4FHH
Hubert, NC
It had pre-toolproof firmware, but the controller was MTS2000. It was a trunking radio and had a DES module too.
