mikeydcg2003
I was sent over to omaha today for work, and i thought, why not program a few freqs and trunks in for something to listen to. I found a few good conventional ones such as the railway trains, etc. I did however find a digital trunk known as ORIN(Omaha Regional Interoporobilty Network). It is a P25 Standard trunk setup. Now from what i had thought i knew, P25 Standard would be a motorola system? I programmed this in as a Type 2 Standard Motorola setup. When i arrived, the scanner would not reconize the trunk. I could flip to the channels and hear what i thought was the control channel. I never did hear any conversations on any of the channels. Could someone instruct me as to what system this should be programmed under so if i head to omaha or wherever, i will know what to program it as. below is the link to the rr db page for ORIN
http://www.radioreference.com/modules.php?name=RR&sid=2361
Thanks in Advance
Mike
Thanks in Advance
Mike
