Programming Question for APX
tsalmrsystemtech
So I have a system and I have the channel Identifiers using PRoCom96 and I am not sure how to put them into my channel ID in the radio. Can somebody me understand it. Also, how to add it correctly. Thanks
Its for a 700 mhz system and the old one is a UHF-2 system that both are in use right now
chrismol1
Yea, there's your band plan for the 700 system. Put them into the CPS bandplan
Moto default for 700 is exactly as its shown on your program
Phase 1 FDMA BASE:762006250 BANDWIDTH:12500 SPACING:6250 TRANSMIT OFFSET:30000000
Phase 2 TDMA BASE:762006250 BANDWIDTH:12500 SPACING:12500 TRANSMIT OFFSET:30000000
I figure your doing NAS, so I hope you know how to do it correctly from a conventional channel
RLeone37
Farmingdale, NY
@tsalmrsystemtech would you mind sending a screenshot of what you currently have programmed in the Astro 25 channel ID section? Having a similar issue with the CPS side of it. First 700 system. Thanks
