Programming Tk-880 KPG-49D
sidthekid1998
brossard,quebec,canada
Hi, I have a Tk-880 & the most recent version of Kpg-49D I found. When I try to read or write to the radio my computer doesn’t recognize the radio. I am using a USB cable. Is there a programming mode I need to activate ?
fwradio
Texas DB Admin
Fort Worth, Texas
USB cables will usually assign a COM Port number higher than 2. Check your Device Manager when you plug in the cable to see what port it picks up.
buddrousa
What version 49D are you using most of the older versions like the 9 pin serial plug while running in a dos window.
There is only one Windows version I know of.
