Programming TK360 with KPG 27D
Sign-Man
Fort Pierce, FL
I am needing to know if there is an online manual for the KPG27D. I have been able to find limited info online as far as setting to Com Port 1 and UHF 450-470 MHZ. I am still getting errors for Windows XP . I have downloaded ser2pl.sys from driver disc ,but Found New Hardware will not do anything when I give the correct path for hard drive or disc.KPG27D does not work when I do a read. It says to take out of scan or transmit or check connection. This radio I have off. It is the old 4 channel TK360. Can anyone help?
ramal121
Lots and lots of watts
Calif Whine Country
From what I can gather, you are having a problem getting your USB to serial adapter to function properly. Until you solve that, you can forget about programming the radio for now.
What cable do you have? Does it show in the device manager when it's plugged in and without errors? If it does show, what comm port is assigned to it?
Some cables will require you to run the install software BEFORE you plug the cable in. You say the new hardware wizard balks when you plug it in. Not good. I would clean out any drivers you installed and find the correct way to get that cable functional.
