BCD325P2/BCD996P2: Programming two different P25 systems
N9RYM
Huntington, IN
I have two P25 systems I want to I want to program together as one system along with their channels and talk groups. The only difference is the System ID's in RR are different. For example: In System/Site 1 on the scanner, I want to program three counties using their channels and talk group, but one county has it's own System ID and the other two have theirs. Or do I need to create separate System/Site for each? Currently I'm not receiving anything from "S1" so I'm trying to rule out a P25 conflict issue or a signal strength.
Indiana - Allen County: County owned, System ID: 597
All other counties: Indiana SAFE-T, System ID: 68D
Joe, N9RYM
Joe, N9RYM
You don't tell us what scanner, that makes a difference in how it is done, but you program each system/site in separately, not all together, and assign scan locations to them. Tell us your scanner and we can help more.
RoninJoliet
ILL
If its a PRO96 you can only put one trunk system in per bank.....
N9RYM
Huntington, IN
Sorry! I have a 996P2. Thanks for the replies. I wasn't sure if I could combine both P25 systems since they're both the same except different System ID's. I'll work on creating two separate systems.
RoninJoliet
ILL
If the system uses the same TGs but different frequencies you can create a second "Site" on the same system ,....
N9RYM
Huntington, IN
So, under one system I'm listening to three counties (A, B, C). Your recommending:
.System
. Site A
. TG A
. TG A
. Site B
. TG B
. Site C
. TG C
