Anyone here ever tried to pick up Project Saver wrist bands? I know it's short range, but so is LoJack and I've had great success in picking up those.
All the licenses I could find were between 218 and 219 MHz.I was unaware of this program. I’ll dial up 217 MHz on the SDR and give it a go.
are they beaconing all the time?All the licenses I could find were between 218 and 219 MHz.
How do you know that is what the actual signal sounds like? What mode is it? It could be just a beeping sound effect the tracking receiver makes.Good video here of what they sound like @ 39 seconds in
They have one UHF license.All the licenses I could find were between 218 and 219 MHz.
Pretty sure those aren't for the wristbands.They have one UHF license.
FCC FRN: 0026908103 (PROJECT LIFESAVER INTERNATIONAL)
FCC FRN: 0026908103 (PROJECT LIFESAVER INTERNATIONAL)www.radioreference.com
The technology hasn't changed. They use this for simplicity and cellular based devices may not have coverage inside buildings or heavy vegetation...or so my S.O. says.I was fairly amused when I pulled into the headquarters for our provincial police and found them running around with these units. IIRC, they were using something around 217MHz.
I explained DF'ing is part of my regular job and gave them a few tips. This was about 10 years ago and I'm sure the technology has improved a lot since then. Great program and I encourage anyone with a wanderer in the house should look it.
It is probably like wildlife tracking. A simple CW pulse, so the receiver would need a BFO like CW or SSB. I once had one of those receivers from Sweden, in the 433 MHz range and adapted it for model rocketry recovery.How do you know that is what the actual signal sounds like? What mode is it? It could be just a beeping sound effect the tracking receiver makes.
Maybe but we have about 5 different types of receivers and everyone sounds like that when we track a subject. I guess at some point I'll dial up my SDR or scanner on the frequency but never felt the need. Its a great service and a couple counties in upstate NY are agencies. The Kiss method is the nice thing.How do you know that is what the actual signal sounds like? What mode is it? It could be just a beeping sound effect the tracking receiver makes.
yeah that's still part of the typical range of VHF tracking beacons. I used to scan it a lot before with a rooftop antenna to listen for banded birds and would occasionally pick one up flying over the rooftop antenna.All the licenses I could find were between 218 and 219 MHz.
