Proscan connection issue
Bonkk083
Union, SC
I'm using a BCD536HP to listen over wifi. It was working, but I got a new AT&T internet/router, and it works on 2 out of the 3 computers. I didn't try them at the same time, I have uninstalled and reinstalled Proscan, still the same issue the computer I got in 2017, which has Intel 3, and the computer I got this year that has Intel 7 works fine, but the computer I got in 2022 that has Intel has the issue, this is one I need to use it on
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
So in other words you're able to connect your 536 to Proscan on 2 out of the 3 computers? Sounds like you already added the scanner to your new wifi? Are you utilizing Proscan's web server function or Remote server over IP or are you simply connecting by comm port (URL?)
Bonkk083
Union, SC
Yes 2 out of 3, I'm going through the URL the IP is 192.168.1.156 on scanner and router
ProScan
Software Provider
Ontario, Calif.
Are you trying to connect the ProScan data (display) & audio directly to the scanner Wi-Fi? Is it both the data & audio not working or just the audio?
