I have been trying to figure this out for some time and ran out of things to check.
ProScan version 21.2
Windows 10 Home
Problem : now and then the ProScan display goes dark and the server stops. I have to turn the scanner off and back on and everything works again.
The SDS200 is connected to a PC via USB and is connected to the Internet via an Iogear WiFi dongle.
When the ProScan display is blank, nothing I do with ProScan changes anything. Rebooting the PC does not correct the issue. I HAVE to power the scanner off and back on. That is all it takes.
When the fault is present, at the ‘URL Audio Setup & Monitor’ page if I select ‘Reconnect’ nothing happens. If I select ‘Restart Scanner Now’ an error box pops up and states ‘Scanner Must Be Communicating For The Scanner Restart To Work’
When I select ‘Auto Detect IP Scanners’ and select ‘Refresh’ nothing appears in the dialog box. The ‘URL Setup’ box is flashing orange.
The Input Sound Device is set to URL.
Any ideas where to start looking?
Windows 10 Home
