ProScan IP
sconheady
Publishing proscan and getting it to the web through a cloudflare tunnel to my down domain. When I click around and click the link to the settings on the webpage it shows my local IP and port. Is there a way to hide that information?
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
You should be more concerned with "showing" your external IP. Sign up for a dynamic DNS service like No-IP if you'd rather not have to use your external IP outside of your LAN if you wish to control your scanner remotely via Proscan's web server
ProScan
Software Provider
Ontario, Calif.
Are you referring to the Remote Address and Remote Port? That's not the server side IP but rather the client side. So if you're access the server from within your network then it will show the IP address of computer running the browser.
If using cell phone WiFi data, that is inside your network. Turn off the cell phone WiFi data so it will use the cell data. Now the phone is outside your network and it will show a different IP address.
