Is there a way to pipe the sds200 thru a LAN...or is that only on the bcd 536?. Trying to figure out if its necessary to connect an audio cable from the scanner to the computer, or not.
Well, except it's wired not through a dongle.With proscan the sds200 sets up just like the 536 audio over lan
Sometimes to get a audio connection you have to cycle the power on the scanner.I've gone thru the setup, and can get the data side working, but not the audio. When I start the web server, I am getting: WI-FI or Ethernet audio not connected to scanner.
You can't have audio on RSOIP if TCP and UDP are not connected. You did select URL in each tab right?Done that....and can start the RSOIP server, but not the web server, or source client. I see TCP NOT CONNECTED, and UDP NOT CONNECTED in Red for the url setup. Connnected ok to port 554 in each instance.
