ProScan: ProScan Software
Saint
Fort Erie Ontario Canada
I am running ProScan 23.5 and have been noticing that when recording frequencies some of them when playing back the audio is extremely tinny in sound and other frequencies are ok. I have tried to make changes in Windows 11 and in ProScan but have not been able to fix this. I never had a problem with this before and don't remember if it started after an update or not. Any help would be appreciated with the problem.
Saint
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania
Set a greater mp3 bit rate as shown below. I have mine set to 64 kbps, audio sounds fine (also running Proscan 23.5 on Win 11 FWIW...)
ProScan
Software Provider
Ontario, Calif.
Saint
No changes in that area in the longest time.
Did you reboot your computer and scanner?
Can you revert to the previous version 23.4 to see if it does the same thing?
https://www.proscan.org/ProScan_23_4.zip
Any time an issue, advise on the scanner type.
Saint
I am running a Uniden 436 scanner, and these are the setup under RECORDERS TAB/audio controls, input sound device is greyed out, mode, format, mps bitrate are also greyed out so I cannot change anything.
Saint
