Protocol list question
K9KLC
Southwest, IL
I think I have found the problem. I was expecting to follow the same routine programming analog that I did with digital. So after realizing this I added 5 analog freqs to the list of conventional ones.......then went to E7 and clicked on each of the 5 new entries separately and putting them in monitor mode then I had access to the CTCSS/DCS settings and was able to get them programmed in zone 4 (Analog) knob pos. 7.
There is no clear cut detailed information anywhere I could find to make this basically EASY task doable. I might type up a step by step analog programming guide because there isn't one....I know the radio scans analog SLOWLY but I am only monitoring 5 channels. If I designed a program like this PPS I would make it so if you were going to program a P25 system, you'd check off the P25 box so that ONLY P25 system configuration pages would appear in the PPS. Same thing with DMR, and Analog.....right now I was jumping all over the place not sure where to go next. Programming these 3 different protocols is very different from each other. Plus with all the options we wouldnt have to bother with. Well its not a scanner!
I'm guessing these were not on the RR database which is only as accurate as the users make it. Had it been in the database it would have been pretty simple to download them into the PPS and things would have been much easier.
Assuming I'm correct did you submit these to the database for the appropriate area? Just curious.
bobruzzo
W1AV
Cranston, Rhode Island
There are a lot of things not in the RR database.....I found many on NE Scan. Or just searching. I can submit the ones I officially have heard. The main problem I find is that no one has made a step by step tutorial for the G5 on how to program this radio. When I first got help and we set up the local P25 system, it was working fine. But when I tried to program both DMR and conventional analog, I was following the same steps as with P25 and therefore I kept getting lost and confused. Programming DMR and analog are 2 different procedures, but not clear in any instruction manual or videos. All the videos on Youtube are too old and not using current PPS or firmware so none of the screen shots match mine. Once I figured out how to get DMR and analog working it was very simple. But without STEP BY STEP help, you will just go around in circles.
K9KLC
Southwest, IL
Because they have not been submitted.
I found some pretty helpful stuff on YouTube but, I had to rely on what I had learned both due to programming other radios and a lot of help on the RR forums from guys due to the other thing you mentioned below.
As you, and all the rest of us found out, yes it's not the same. I have added frequencies for conventional analog manually but it's sure way easier when you have them in the Database here. It took me longer to get my laptop out, and fire it up for programming than it did to go to RR and import a conventional analog system from MO where I was going for my son's wedding mid April. I was sure glad those frequencies were there and I was able to simply import them. Would have taken way longer entering them all by hand. A simple download, a few tweaks and I was ready to go.
Glad you're getting the hang of it, and making progress.
bobruzzo
W1AV
Yes I think over time I will have a better understanding. I programmed a few more analog freqs and its very easy to do it manually. I have been bringing this radio to work the last 3 days and my work partner is really enjoying listening to all the calls. We drive most of the day and no matter where we go, the reception is good. He never listened to a scanner before and wants to get one. I might need to brush up on programming a P25 system at some point cause I don't remember every detail. But I tweaked my settings and got all the talk groups organized. Its too bad theres onl;y room for 64 TGs. I woulda liked at least 100, so I had to just put in the basic PD and FD main dispatch and fire grounds.....but thats for the whole state of RI! Still plenty to hear.
K9KLC
Southwest, IL
Well...it will receive way more than 64 but it will only identify 64 in any single knob position. You can use talk group monitor and it will receive every TG that's coming out of that site. For instance, I have the ones I'm mainly interested in in Zone 1 Knob 1, then in Zone 1 Knob 2, I use TG monitor and it receives everything coming out of that site. I still have a bunch of them labeled in that knob position also but the rest come up as only the TG ID number. After a while you will learn voices, streets, and even some of the numbers and it gets easier to identify what's happening. You're a premium member at RR, you can use the import from RR database feature in the PPS, and it makes things way easier (at least to me). Yes I tweak and change manually still along the way, but that import feature was a blessing.
Time, practice, doing things wrong then learning, asking questions are all part of this (or most) hobbies. Just the other day going to take a trip, I accidentally put in the wrong site on a trip I was taking. For some reason I couldn't get one of my "full spectrum scans" to pick it up either. (that's a whole different world to delve into). But I did get the analog stuff right and was able to listen to Local PD the two days I was down there. Was great keeping track of things while on a trip like that.
Keep going, you'll get it. I still need help on occasion doing this, that or the other on the thing but I've come a ways from day one with a LOT of help from folks here.
bobruzzo
W1AV
When I set up the radio the first time I got help with setting up the local state P25 simulcast system. I have 5 sites on 5 separate knobs. I only put in the most active TG's like PD and FD Dispatch with some fireground TG's too. Along with all the other stuff on the system that is interesting. It works great. The 6th knob has the same system only set up with a "wildcard" which gets all TG's on the system but doesnt display the names. Knob 7 I set up with some local analog channels, and knob position 8 is a bunch of local business DMR channels. So far I can only figure out how to use just the top row, knob positions 1 thru 8 Zone 1 and I labeled it "RISCON" cause thats the state systems name. Even tho positions 7 and 8 are not related to the state system. Also if you look at the pic below, I have all the analog and DMR freqs filled in 3 zones.....is this supposed to be that way? I dont know how to program a NEW zone to use like the zones up at top. For example if I fill in another area with, say 5 or 6 public service freqs and wanted to assign a knob position AND ZONE, would I just creaet a NEW zone further down list and associate the 5 or 6 new freqs to it? It seems there are zones to STORE freqs and zones to STORE systems. This is what confused me when I first got started.
K9KLC
Southwest, IL
Actually you do it the way you want and organize the way. you want. If you import from RR, it gives you the option to use the public resource manager or start a new zone and such. Thus far personally I have used the create new zone choice but in hind sight I may have done that differently had I known then what I know now. (but it all still works to get things in there).
By right clicking on the Zone you can add a new one, and by right clicking on the knob positions you can move them around or even copy and paste them to different locations. It takes as many knob positions as it takes to get in there what you need for conventional stuff but remember you can only scan 16 positions with the scan position.
Yes to add more you create a new zone (or do it with the import if you choose) and just import them. Then, if they're not the way you like them, move them around as needed to make it easier if you manually switch knob positions to monitor only one thing from your conventional list.
