Provoice/arcgis info help
merlin
DN32su
Just acquired some Ericsson jaguar 700Pi radios at auction. Been around EDACS enough I can work with that but would like to understand how the provoice works.
Can anyone provide links to in depth info for this, including but not limited to programming the provoice.
All the radios work fine conventionally but want to set up the provoice.
Seems they were all 'de-channeled' when pulled from service. A couple are missing knob caps, a source for those would be great.
Any help here would be hot, thanks in advance
Forts
Ontario, Canada
In RPM, go to SETS - Conventional Frequency Set. Then for the channels you want to use digital on change the Voice Mode drop down box from Analog to Unencrypted. Now, go to SYSTEMS - General and create a conventional system. Then go to the conventional tab, pick the system and look at the Private Options box. From here you can select the vocoder to be used - None (analog), Aegis or ProVoice. And obviously to use Aegis or PV your radios need to have the proper features enabled. If you are using Programmer vs RPM the steps are essentially the same.
merlin
DN32su
Thanks. Much of that I already have under belt, what I am hoping to find is the technical stuff related to provoice that my radios are optioned for.
Programming is no issue.
merlin
DN32su
More: I have 2 portables and a mobile on my companies 800 Mhz talkaround and working. In ProGrammer then just program for private (provoice) ??
Forts
Ontario, Canada
I'm not sure what kind of 'technical stuff' you mean....
merlin
DN32su
What makes it tick, like what is under the hood if you will. I know there are data encryption processors sandwiched between A/D-D/A converters etc, that is about all I know of it.
merlin
DN32su
Well, I am digging up a little dirt on AEGIS, seems the big difference to provoice is in error handling.
Now if EDACS gets phased out I presume AES and other networking protocols will take the place.
