WS1095: PSR-800 and WS-1095 software
WYDOR
Laramie County
Can the WS-1095 be programmed using the PSR-800 software? I ask because I have the PSR-800 and sure would like to use that configuration rather then reinvent the wheel. Thanks.
Swipesy
Northern Ohio
Yes but. You can open the PSR-800 configuration in the WS-1095 EZScan software but then you should click on "Restore Factory Defaults" and then reset your preferances before copying the configuration to the WS-1095 SDCard.
W6KRU
Vista, CA
I tried using the PSR-800 software on my WS-1080. It worked but caused a quirky problem that was only resolved after a complete reset.
TAbirdman
MO
that's true as the config file is set up for the 800 and not the 1095. That is why it was mentioned to do a reset before sending it to the scanner.
dmaria
Tried that the first day and the scanner would not boot up.
