PSR-800: PSR-800 battery clock/date not holding
bravo14
Polk County FL
@Whistler_Support When Whistler did the upgrade on the certain radios to DMR and other items to it. I had no issues with radio after upgraded about a year after it the time/date clock not holding I have to enter it each time when I power it down to change batteries since I don't charge batteries in the radio. Is there a easy fix? Thanks.
Whistler_Support
Whistler Representative
Bentonville, Arkansas
There is a 470uf 6.3V Tantalium capacitor that holds the voltage up briefly when changing batteries
If you are not having battery life issues, I suspect it is no longer holding a sufficient charge to give you time when changing the batteries.
If you are having battery life issues, it could still be this capacitor as it may have become resistive.
It is located on the logic pcb opposite the Micro SD card with the component designation C401
It is polarity sensitive component so it you choose to change it, be sure to note the polarity
jkahn
Very good looking Member
Silver Spring MD
Or try this first.
It takes several hours to charge the capacitor. Try removing the batteries (you don't want to charge them in the radio) and plugin the A/C wall charger to power the scanner up. Left it run for a couple hours and see if that fixes the problem.
Whistler_Support
Or try this first.
While this may be true of some products, I can assure you this is not going to fix the issue the customer is having with the PSR-800
