psr 800 driver
n1leu
Meriden,Ct.
Greetings,
I have the GRE PSR 800 and I am running Win XP, I need the driver for the scanner without the garbage driver detect trash where can I download it?
Thank you in advance for your help and 73,
Dave
N1LEU
Download the EZ Scan software and install it. Once installed, it'll detect the scanner.
http://greamerica.com/
I'm not sure what the driver link is at the bottom. I'm pretty sure the EZ Scan software has it too...
marksmith
Anne Arundel County, MD
You need the ez scan software anyway for updates, so install it. It will allow you to do DB updates to the SD card put in a drive with a converter. My experience is th as t it WON'T provide a driver allowing your computer to see the radio for firmware updates.
I found the actual PSR 800 driver somewhere on the RR forum, so it is here somewhere.
536/996P2/HP1e/HP2e/996XT/
396XT/PSR800/PRO668/PRO652
