Psr-800
sabo
Mesa, AZ
OK..my 800 will be here in 2 days..whats the best way to run this scanner as a Desktop..no portable..do I need to buy a power cord or what. Thanks
jaspence
Michigan
Psr 800
It runs on 5 volts from the USB cable. An inexpensive USB wall charger should easily handle the needs. It will not charge the battery while scanning, so if you use rechargeable batteries, get a good charger for double AAs. Most of us with experience do not charge our batteries in the radio. I had a NiCd short and melt the radio several years ago.
troymail
Silent Key
Use the cable that comes with it - plug it into your PC - or you just need to get that USB house current adapter --
or, as I do -> just have at least two sets of batteries-- one always on external charge.... I like to be able to "go mobile" at any moment.
stetsonbob
Canton, OH
I would recommend turning location Off in the general tab. This could save you headaches later.
sabo
Mesa, AZ
just waiting on my new batts to show up..running on Alkaline copper tops..getting over 6 hrs on a set..not bad..my PRO-96 only got 4 hrs... and I put the PRO-96 to sleep..while looking for a new owner.
